1999 Jaguar Vanden Plas 99 Jaguar v8 Shaky Engine "Res
98,000 MILES • V8 • 2WD • AUTOMATIC
KDTDALTEX
Last year i was getting a shaky engine at idel and very rough running and then it quit and wouldn't start. Dash lights said "Restricted Performance", ABS, Coolant Low, orange and red bars.
Jaguar dealer in Plano Texas checked for vacum leaks (non found)
Replaced the throttle body (slight change)
Then replaced one ignition coil (big change, ran smooth bur every now and then "Restricted Performance" would pop up then then go away.
Today i got the shaky engine again? Dash lights said "Restricted Performance", ABS, Coolant Low, orange and red bars. Car will restart and run but it shaks and is under powered. What do you think?
Dec 21, 2008 at 9:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
So when you replaced one coil pack it fixed the issue for the most part, correct? I suggest replacing the other coils as well. If one is faulty, the others are probably just as bad because they all have went through the same mileage as the one that was replaced.
Dec 21, 2008 at 12:24 PM
