1996 Jaguar Vanden Plas Adjustable Steering Column
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAH
So the column goes in and out and up and down. The in and out seem to work but the up and down is iffy. Works sometimes, not others. Also it does not seem to go up all the way. I am looking for information about what parts I need to track down to fix this. It is unclear from my searches.
Dec 16, 2008 at 6:40 PM
KHLOW2008
  • 41,812 POSTS
Hi sah, I could only find an exploded view of the steering column and hope it helps.
https://images.2carpros.com/forum/automotive_pictures/192750_Steering96Jaguar_1.jpg
I believe the part that you should check is the tilt pivot.
Dec 17, 2008 at 4:00 AM
SAH
Thank you but I still could use a bit more information, part wise. I did some looking on line for that part and I come up with 2 items:
OES Genuine Steering Column Motor
1995-1997 Jaguar Vanden Plas - $250
OES Genuine Steering Column Adj.
1995-1997 Jaguar Vanden Plas - $90
I do not see a motor in the view you showed but I assume it must be there. Do I need both of these or just one or am I looking at the wrong thing?
Thanks,
Sean
Dec 17, 2008 at 10:01 AM
KHLOW2008
  • 41,812 POSTS
Hi Sean,
Sorry I could not find any parts info from Mitchell1. Googling did not help much as well.
The 2 parts that you provided seems seems separate and depending on the fault and rectification, I believe the motor is what you should be looking at.
I will try to get it from my fellow technicians to see if they could be of assistance.
Sorry to have to keep you waiting.
Dec 18, 2008 at 12:27 AM
SAH
No stress. This is a great site and I am glad I found it. I have tons of questions and will be posts them soon (and I am more then happy to pay for each one!). I want to cherry out this car. I ordered the CDROM with the service manuals the other day.
Thanks,
Sean
Dec 18, 2008 at 7:15 AM
  • 55,561 POSTS
Hi the problem should be in the motor, or the controller. Can you prob the feed wires to see if the power comes and goes?
Dec 22, 2008 at 10:25 AM
