I have a 1995 Jaguar Vanden Plas with automatic transmission. Recently I had a problem with losing transmission fluid and discovered a leaking cooler in the radiator. Once I had that fixed and reinstalled I started having problems with it not shifting back to first when you come to a stop, but if you shut the car off and restart it, everything is back to normal. Until you get into drive or overdrive again. Also it seems to have lost reverse. Any ideas.
Jul 5, 2010 at 2:35 PM
