1995 Jaguar Vanden Plas door locks
110,590 MILES • 6 CYL • 2WD • AUTOMATIC
DONALDDESI
When either front door is locked from the outside (with key), the other 3 doors do not lock as they should, but the alarm is armed and works fine. The lock switch on the dash does nothing.Also unable to open trunk with key or button release. I will donate if you can help.
Oct 16, 2009 at 10:09 AM
DAVE H
  • 13,383 POSTS
check the wiring and main switch for the lock fault .. you need a locksmith to access the trunk
Nov 27, 2009 at 12:08 AM
