WERE IS THE FLASHER LOCATED AND IF ITS NOT THE FLASHER WHAT COULD IT BE?
Jan 17, 2010 at 11:52 AM
BLUELIGHTNIN6
✓Experienced Mechanic
turn signal / hazard flasher relay is located under left side of dash panel. if flasher is OK, check fuses and bulbs. If all OK suspect faulty signal switch
Jan 17, 2010 at 12:41 PM
ELNACO1980
MEMBER
THANX FOR THER INFO
Jan 17, 2010 at 1:34 PM
