1988 Jaguar Vanden Plas engine surges
1988 JAGUAR VANDEN PLAS
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUNCHY
engine surges and runs very rough, when put in gear will hardly pull itself
Thanks
P.S. had a new fuel pump and filter not long ago.
Jun 5, 2010 at 5:11 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
Was the tank flushed when the pump was done? have you had the injectors cleaned? check for any vacuum leaks, check for any unresolved fault codes in the ECU, check plugs and leads, start here.
mark (mhpautos)
Jun 5, 2010 at 8:14 PM
BUNCHY
Tank was flushed, new plugs and wires.Cpu showed code 2 Mass air flo, cleaned leads, code no longer showing. Whatever happened was instant as car was running perfect.
Thanks
Jun 6, 2010 at 8:02 PM
  • 31,937 POSTS
May be a vacuum leak, have you checked all vacuum lines, can you hear any odd sucking ? air noises?
mark
Jun 6, 2010 at 9:25 PM
BUNCHY
Vaccum lines appear to be ok, no sucking noises. If you attemp to excellerate fast, you get a backfire.
Thanks
Jun 12, 2010 at 3:59 PM
  • 31,937 POSTS
This can often be faulty plugs & leads, check these.
mark
Jun 12, 2010 at 7:47 PM
