1990 Jaguar Sovereign Air conditioner/Gasket
72,500 MILES • 4 CYL • 4WD • AUTOMATIC
PAULI PALM SPRINGS
Two issues-oil gasket leaking..What to do? Should I have one that mechanic says he can get rebuilt?
2ndissue-the worst. I am living in desert. My air went out. Stopped. Service guy gave it a recharge & it lasted 3 weeks. Stopped again Have hot air blowing
Yes, it was converted. What can I expect to get air-do they have to put whole new system since car is l990 or what? Frantic, frankly, as on a tight budget, no way to buy or lease other car. HELP, please
Jun 6, 2010 at 10:45 AM
  • 31,937 POSTS
Hi there,
With out knowing where the oil leak is i can't comment, if you can advise on this leak that would be a big help, as for the A/C i would first get a leak test done, this may be a simple fix if it is a leaking hose union.
Mark (mhpautos)
Jun 6, 2010 at 10:50 AM
PAULI PALM SPRINGS
Do I have to go to a Jag mechanic to get leak test or can a place like Meineke do it?
re Gasket-leaks bown oil toward front of car. that's all I know....Mechanic says gasket bad and wants $900 to fix it.
Disturbed about both as gasket affects power steering..but AIR here in the desert-, my car is undriveable. Would you go to Dealer, a Jag mechanic or where? Thanks
Jun 6, 2010 at 10:55 AM
  • 31,937 POSTS
The A/C can be checked by any workshop that does A/C repairs. What they will do is add a small charge of refrigerant with a leak detector dye, as it leaks it will leave a stain, i would get a second quote on the oil leak and a better description of what is wrong, just a gasket sounds a bit dodgy to me.
Mark (mhpautos)
Jun 6, 2010 at 11:01 AM
PAULI PALM SPRINGS
Thanks for reply. It is the gasket that affects the power steering...
Re the A/c they did a test, saw that it leaked, charged it and it ran for 3 weeks. Not working now.
What am I up for on this issue since it's a l990? Do they repair the leak, or have to do a whole new system..that's my worry. Thanks
Jun 6, 2010 at 3:23 PM
  • 31,937 POSTS
Do you know if it is the steering rack or the pump that is leaking/ this will make a fair difference in Price, as for the A/C leak, it may be as simple as a seal but we do need to get the dye leak test done to confirm the actual cause of th leak.
mark
Jun 6, 2010 at 6:53 PM
