2004 Jaguar S-Type Tires wearing inside
2004 JAGUAR S-TYPE
53,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPIRITGEAR
I bought 2 new tires "Perelli's" at a chain (Tires Plus), in addition I asked them if they could do a front end allignment, after about 3 months or 5,000 miles Imy front tires were wearing, I went back and they said the alignment was fine but did another one, I went back 3 times since because the wear had gotten so bad that it was pulling the car. This time I told them to swithch the back tire to the front and if the old tires do not show wear on the inside then it must something wrong with the tires I purchased. They said anything was possible. Well it has been 2 months and another 3000 miles on the old tire in the front...to my supprise there is no wearing on the inside to be found. Any advice would be appreciated. If the car is in total allignment what else could make the tires wear uneven or "towing".
Jan 22, 2010 at 1:48 AM
DAVE H
  • 13,384 POSTS
Premature Tire Wear
Improper tire inflationCheck tire pressure
Front alignment out of toleranceSee ALIGNMENT SPECS in WHEEL ALIGNMENT section
Suspension components wornSee SUSPENSION section
Steering system components wornSee STEERING section
Improper standing heightSee WHEEL ALIGNMENT
Uneven or sagging springsSee SUSPENSION section
Bent wheelSee WHEEL ALIGNMENT
Improper torsion bar adjustmentSee SUSPENSION section
Loose or worn wheel bearingsSee WHEEL BEARING ADJ. in SUSPENSION section
Worn or defective shockReplace shock absorbers
Tires out of balanceCheck tire balance
Feb 7, 2010 at 10:52 AM
