2003 Jaguar S-Type Blowing Hot Air
55,000 MILES • 6 CYL • 2WD • AUTOMATIC
SSLJ
The Passenger side is blowing out cold air and the drivers side is blowing out hot air. What should I test to see what the problem is?
Jul 2, 2010 at 10:00 AM
JAGTECH360
  • 74 POSTS
Evaporator temperature sensor is the most likely culprit. You might want to try disconnecting the battery for fifteen minutes and allow it to perform a hard reset. If this doesn't take care of it you will most likely need to take it to the dealer.
Sep 29, 2010 at 11:02 AM
