2002 Jaguar S-Type Cooling Fan Stays On
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
GERWITZ
I had an overheating issue, we have replaced the thermostat, coolant reservoir, upper radiator hose. Doesn't overheat but temp flucuates now and the cooling fan runs a long time after the engine is shut off, which it didn't do before.
May 29, 2010 at 7:40 AM
  • 75,988 POSTS
Check the coolant temperature sensor and the engine temperature gauge switch if it has one and also if the fan relay is sticking
May 29, 2010 at 11:36 AM
GERWITZ
[quote:47cd4553b4="rasmataz"]Check the coolant temperature sensor and the engine temperature gauge switch if it has one and also if the fan relay is sticking[/quote:47cd4553b4]
Is this something I can check or do I have to take it to a repair shop?
May 29, 2010 at 3:19 PM
  • 75,988 POSTS
Take it to the repair shop-this is not a DIY thing.It's beyond your control.
May 29, 2010 at 11:03 PM
