HOW DO YOU REMOVE THE INSIDE DOOR PANEL TO REPLACE THE WINDOW MOTOR OR ASSEMBLY FOR THE REARDOOR
Feb 24, 2010 at 5:38 AM
DAVE H
✓Experienced Mechanic
Rear Door Trim Panel
Removal
Remove the rear door interior handle bezel.
Remove the rear door trim panel retaining screw cover.
Remove the rear door trim panel retaining screws.
Detach the rear door trim panel.
Remove the rear door trim panel.
Disconnect the window control switch electrical connector.
Installation
To install, reverse the removal procedure.
