2001 Jaguar S-Type Tool to remove front rotor hub
2001 JAGUAR S-TYPE
ADOLPHE
Brakes problem
2001 Jaguar S-Type 6 cyl Automatic
I cannot remove the front rotors on this vehicle. What tool do i need to remove the front rotors from the center hub?
Apr 4, 2010 at 2:38 AM
DAVE H
  • 13,384 POSTS
give it a few taps with a hammer !
Removal (Brembo)
Remove disc brake pads. See FRONT DISC BRAKE PADS .
CAUTION:Only remove the bolts securing the caliper anchor bracket to the hub carrier. DO NOT loosen any other caliper bolts.
Remove front caliper mounting bolts and remove caliper from vertical link. See Fig. 12 . Set aside and support caliper.
Remove brake disc from hub.
Clean and inspect all associated parts.
Installation (Brembo)
CAUTION:The front brake discs are directional and must be installed to the correct side of the vehicle. The left disc can be identified by a groove running around the circumference of the outer disc wall. See Fig. 1 .
Install brake disc to hub.
Install caliper to vertical link. Fig. 12 . Install caliper mounting bolts and tighten to specification. See TORQUE SPECIFICATIONS .
Install disc brake pads. See FRONT DISC BRAKE PADS .
Removal (Except Brembo)
Remove the caliper from its mounting and secure aside. See Fig. 7 .
Remove brake pads from caliper housing and discard brake pads. See Fig. 8 .
Remove the caliper carrier mounting bolts and remove the carrier from the vertical link. See Fig. 17 .
Installation (Except Brembo)
Install caliper carrier to vertical link. See Fig. 17 . Install caliper carrier bolts and tighten to specification. See TORQUE SPECIFICATIONS .
Apr 5, 2010 at 9:17 PM
  • 55,433 POSTS
There is nothing special about removing the brake rotor, it must be stuck on the hub,(rusted) please go over this video to help you remove the front brake rotors.
https://www.youtube.com/watch?v=EIqEFHd754I
Please upload a short video in your response of the problem, so I can see what's going on
Mar 1, 2026 at 3:44 AM
