2001 Jaguar S-Type SHOWS HEATING AND JERKING
2001 JAGUAR S-TYPE
84,000 MILES • V8 • AWD • AUTOMATIC
TEDDYBLK1
Hi , please i bought my jaguar less than six months ago, first the back window is broken, two sometimes when i start the car the heat arrow goes straight to hot, but after a while it goes back to cool.Then also when i stop at the light or to get something the car jerks, like you know jerk and then when im driving i dont feel it.Whats the problem?Thanks
Aug 9, 2010 at 8:48 AM
JAGTECH360
  • 74 POSTS
This model year V8 had thermostat problems. I recomment replacing that for starters (be sure to remove the bleed cap when refilling coolant but don't crack the housing). There is also a chance the waterpump could have a loose impeller (not as likely but I've seen these with that concern).
The jerking you are refering to is a missfire. Check the plugs but most likely a failed ignition coil.
Sep 28, 2010 at 3:54 PM
