2001 Jaguar S-Type location of ingintion coil
133 MILES • V8 • FWD • AUTOMATIC
SHERELLE
how to replace ingintion coil
Sep 9, 2010 at 2:14 PM
  • 75,988 POSTS
Service and Repair Ignition Coil-On-Plug Removal Left and Right-Hand Bank Disconnect the battery ground cable.
https://images.2carpros.com/forum/automotive_pictures/12900_i1_4.jpg
Remove the engine cover. Left-Hand Bank Remove the evaporative emission canister purge valve. Remove the oil level indicator.
https://images.2carpros.com/forum/automotive_pictures/12900_i2_4.jpg
Detach the power assisted steering fluid reservoir.
https://images.2carpros.com/forum/automotive_pictures/12900_i3_3.jpg
Unclip the engine breather hose. Right-Hand Bank Remove the air intake tube. Left and Right-Hand Bank
https://images.2carpros.com/forum/automotive_pictures/12900_i4_1.jpg
NOTE: Left-hand bank shown, right-hand similar. Remove the ignition coil cover.
https://images.2carpros.com/forum/automotive_pictures/12900_i5_1.jpg
Disconnect the ignition coil electrical connector.
https://images.2carpros.com/forum/automotive_pictures/12900_i6_1.jpg
Remove the ignition coil. Installation
https://images.2carpros.com/forum/automotive_pictures/12900_i7_1.jpg
To install, reverse the removal procedure. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Sep 9, 2010 at 4:54 PM
