2001 Jaguar S-Type
JURE
  • 2001 JAGUAR S-TYPE
Interior problem
2001 Jaguar S-Type 6 cyl Two Wheel Drive Automatic
how to replace window switch Lh
Sunday, May 3rd, 2009 AT 6:32 PM
DAVE H
  • 13,384 POSTS
Removal & Installation (S-Type)
Remove door latch bezel and door trim panel retaining bolt. Remove door pull handle screw cover and door pull handle retaining screws. Release clip at upper rear of trim panel by lowering glass and pressing case inwards. Detach interior door trim panel.
Disconnect door trim harness electrical connector and remove door trim. Disconnect driver door module electrical connector. Disconnect window switch electrical connector. Remove electrical harness retaining screw, disconnect window switch electrical connector. Remove door trim panel armrest and remove window switch. To install, reverse removal procedure.
Wednesday, November 25th, 2009 AT 6:30 PM
