2000 Jaguar S-Type fuel data error
2000 JAGUAR S-TYPE
154,000 MILES • 6 CYL • 2WD • AUTOMATIC
GRAHAM1961
my 2000 s type auto comes up with the folling message FUEL COMPUTER DATA ERROR this realy frustrating as it shuts the engine down as i do a lot of motorway driving its quite dangerous as you can imagine i have taken it to the main dealers but they cannot locate the problem
Nov 27, 2008 at 7:01 PM
DAVE H
  • 13,384 POSTS
FUEL DELIVERY
Fuel Pump
Output signal from ECM or PCM controls relay that operates fuel pump. When ignition is turned on, pump will operate for 2 seconds without ignition switch being turned to crank engine, after which time pump will be de-energized. In addition, if engine stops with ignition on, pump will be de-energized after 2 seconds. Pump operates continuously while ignition switch is set to crank engine, or when engine is running. Supercharged vehicles are equipped with a secondary fuel pump. Both fuel pumps operate under certain conditions.
Returnless Fuel System (S-Type)
The returnless fuel system is used to reduce fuel tank vapor. System does not use a return line or pressure regulator. Fuel pressure is controlled by PCM. A pressure relief valve, located at the front of the fuel rail, allows system to be depressurized before fuel system service.
Nov 8, 2009 at 12:12 PM
