2000 Jaguar S-Type Fail Safe Engine Mode Light
29,000 MILES • 6 CYL • 2WD • AUTOMATIC
MHS112752
Yesterday, I started my car with a quick charge, battery charger. After the car started I noticed the fail safe warning lamp had turned on. I have driven the car with no noticable change in performance. It drives as it always did. I am wondering if the fifty amp quick charge sent an errant message to the onboard computer and if so, will disconnecting the battery reset the lamp.
May 27, 2010 at 5:25 PM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated It is possible the PCM/ECU has picked up on an overcharge/overload to the electrical system and turned on the CEL .. disconnecting the battery will not help .. you need to have the vehicle plugged into a diagnostic computer to check the codes and erase the light
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1150.png
May 29, 2010 at 9:26 PM
