2000 Jaguar S-Type brake and side indicator lights
39,000 MILES • V8 • 2WD • AUTOMATIC
SURESH_BAGGA
brake and side indicator lights stays on even when the
key is removed
Oct 8, 2010 at 8:02 AM
JAGTECH360
  • 74 POSTS
Check in the trunk for the transit relay connector hanging down. It will be located between the battery and the body. These have a tendency to corrode up (also may have water in the boot). If that's not the problem, there is a fuse in the boot fuse box (unsure of the location # or positon) that may be open causing a voltage back feed.
Oct 30, 2010 at 3:50 AM
