2000 Jaguar S-Type Antifreeze
142,000 MILES • V8 • 2WD • AUTOMATIC
RAMBACHI
I am losing about couple of ounces antifreeze every week. There appear to be no apparent leaks on the ground. Its hard to notice because I park on grass drive way. The last mechanic said he didn't see any hos e leaks. He said your head gasket could be starting to go bad. But the car runs smoothly and there is no visible smoke coming out of exhaust. I seem to notice the antifreeze is low when I have the AC turned on in this current hot weather. What do you think is the problem
Jul 24, 2010 at 6:24 AM
JAGTECH360
  • 74 POSTS
It's not your headgasket. It is the coolant reservoir. It leaks down the inner fender and can be hard to spot a leak. It only leaks when the coolant is under pressure and hot. 99% reservoir 1% might be the seal to the t-stat housing which whill leak into the engine valley also making the leak hard to see.
Ps. I recommend not going back to that repair shop. They should be able to find a leak.
Sep 28, 2010 at 4:02 PM
