1999 Jaguar S-Type Front wheel hub
1999 JAGUAR S-TYPE
123,000 MILES • 6 CYL • 4WD • AUTOMATIC
KATSCAR1
How the hell do you get it off, 4 bolts are out but it won't move at all?
Feb 24, 2009 at 1:07 AM
DAVE H
  • 13,384 POSTS
Pry it off while tapping with a hammer !
Removal
Remove the brake disc. For additional information, refer to FRONT DISC BRAKE ROTOR .
Detach the anti-lock brake (ABS) sensor.
Remove and discard the retaining clip. (1)
Detach the ABS sensor. (2)
Remove and discard the O-ring seal.
Remove the wheel hub and bearing retaining bolts.
Remove the wheel hub and bearing.
Nov 8, 2009 at 8:43 PM
