1990 Jaguar S-Type Alarm beeping
38,000 MILES • V12 • 2WD • AUTOMATIC
JAGPIPER
Battery went dead. Now after jump starting and turning the ignition off, there is a beeping that occurs every 4 seconds or so. Have no idea how to turn it off, but afraid it will eventually run down the battery again.
One email(gasoholic) suggested removing a fuse beneath the steering column to solve the problem. Not sure which fuse corresponds to this beeping.
Any suggestions??
Aug 21, 2010 at 4:35 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Is the radio on? is there any electrical equipment that is not working to your knowledge.
mark (mhpautos)
Aug 21, 2010 at 8:42 PM
JAGPIPER
The car radio was on when battery went dead. No electrical problems with the car.
Ray
Aug 22, 2010 at 1:11 AM
  • 31,937 POSTS
Hi there, i would start with a diagnostic scan just to check that the battery problem did not trigger a system fault anywhere, start here.
mark (mhpautos)
Aug 22, 2010 at 12:02 PM
JAGPIPER
Mark,
I'm confused by your response. What is a diagnostic scan and how do I perform it?
Evidently this is a common problem with the XJS Jaguars, and not specific to my vehicle. See my original question. One owner suggested disabling by removing a fuse but I'm not sure if this would work or which fuse to pull.
Ray
Aug 22, 2010 at 12:24 PM
