How much can you compress coil springs?
10,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
STEVE CLOUTIER
  • 13 POSTS
Can they be compressed to no space between coils? Rear shocks.
Sep 9, 2021 at 1:32 AM
SQM
  • 6,383 POSTS
You can put the springs on a press and have it pressed to that point. However it should not be like so when in the vehicle.
What issues are you having?
Is your springs bottoming out?
Let me know a little bit more information and I will be happy to assist.
https://www.youtube.com/c/2carpros/featured
Sep 9, 2021 at 2:29 AM
STEVE CLOUTIER
  • 13 POSTS
Changing rear shocks. Shocks are inside the spring, so I had to remove the springs. I had pry the springs out after compressing them as far as I felt I should.
Sep 9, 2021 at 11:41 PM
SQM
  • 6,383 POSTS
Got it. It's fine to compress them all the way during replacement. You just don't want the springs to stay that way for extended period of time.
Sep 10, 2021 at 2:55 AM
STEVE CLOUTIER
  • 13 POSTS
Would you compress these using strut compressors?
Sep 15, 2021 at 12:53 AM
SQM
  • 6,383 POSTS
Yes, that type of spring compress toll will work.
Just remember when you use these spring compressors, you want to turn each one of the arm few turns at a time. Do few turns on one then few on the other, back and forth. You don't want to compress one of the arms too much as it can have uneven pressure and pop out.
Sep 15, 2021 at 1:00 AM
STEVE CLOUTIER
  • 13 POSTS
Thanks for the advice.
Steve
Sep 15, 2021 at 2:21 AM
SQM
  • 6,383 POSTS
You are welcome. Let me know how it turned out.
Sep 15, 2021 at 2:46 AM
