Jaguar S Type Radio
JAGUAR
TED OSTROW
  • 5 POSTS
The display, controls and disc player appear to work but there is absolutely no sound.
The radio has a remote disc changer and what appears to be a power amp in the trunk.
The fault was once intermittent but now is consistent.
Can you advise how to remove the radio from its console?
Ted Ostrow
Nov 17, 2007 at 2:13 PM
BMRFIXIT
  • 19,053 POSTS
[quote:1d8f59fbfa="Ted Ostrow"]The display, controls and disc player appear to work but there is absolutely no sound.
Ted Ostrow[/quote:1d8f59fbfa]
is it on mute due to cell phone use
check BCM for codes
Nov 17, 2007 at 3:45 PM
TED OSTROW
  • 5 POSTS
[quote:086482485b="BMRFIXIT"][quote:086482485b="Ted Ostrow"]The display, controls and disc player appear to work but there is absolutely no sound.
Ted Ostrow[/quote:086482485b]
check BCM for codes[/quote:086482485b]
Its not the mute feature. The radio just began working again today. I'm beginning to believe it might be an intermittent ground at the trunk-mounted power amp. I have no idea where to locate the ground connection though. Any info would be appreciated.
Ted Ostrow
Nov 19, 2007 at 1:14 PM
BMRFIXIT
  • 19,053 POSTS
is it on mute due to cell phone use check BCM for codes[/quote:bd6c46fa08] Its not the mute feature. The radio just began working again today. I'm beginning to believe it might be an intermittent ground at the trunk-mounted power amp. I have no idea where to locate the ground connection though. Any info would be appreciated. Ted Ostrow[/quote:bd6c46fa08] here what i have make sure its not the switch s on steering
https://images.2carpros.com/forum/automotive_pictures/99387_jag_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_jag1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_jag12_1.jpg
Nov 19, 2007 at 1:32 PM
TED OSTROW
  • 5 POSTS
To BMRFIXIT
Thanks for your prompt and helpful response. I attempted to leave you positive feedback on that site-feature, but it would not work.
I'll uncover the rear bulkhead and check the ground for continuity. Thanks again. Ted Ostrow
Nov 20, 2007 at 3:55 AM
BMRFIXIT
  • 19,053 POSTS
[quote:59bd169452="Ted Ostrow"]To BMRFIXIT
I'll uncover the rear bulkhead and check the ground for continuity. Thanks again. Ted Ostrow[/quote:59bd169452]
thank you for trying and i will let the boss know
Nov 20, 2007 at 4:56 AM
FSTRANGER302
  • 117 POSTS
[quote:afffeb0172="Ted Ostrow"]The display, controls and disc player appear to work but there is absolutely no sound.
Ted Ostrow[/quote:afffeb0172]
hello, if the amp has gone bad the radio willnot have any sound. if you can get codes from the radio with a scanner, this will help, let me know thanks pat
Nov 24, 2007 at 1:18 PM
TED OSTROW
  • 5 POSTS
To: fstranger302
Thanks for your suggestion. The problem is intermittent and the radio is operating normally at this time. I believe the problem is an intermittent ground connection. Another member sent a wiring diagram showing the ground at the rear bulkhead. The drawing does not match my car, which is a 2003 model with fold-down rear seats.
I still have to remove the trunk liner to follow the wiring harness to a ground lug.
Nov 27, 2007 at 3:49 AM
