1999 Jaguar XK8 No Fuel Pressure
JAGUAR
DESHAN
I have a 1999 Jaguar XK8 convertible with about 90,000 miles. I was driving it in the foot hills of west georgia and it didn't seem to have a lot of its power, thought it might be time to replace plugs and tune up. Parked the car and it wouldn't run after a couple of hours. It ran very rough and i got the feeling it was starved for fuel. Checked the schrader valve on the fuel rail, and it had some pressure at first then it went to none after some time. Checked the fuel pump fuse and the relay, it clicks as if its picking up. 99% sure its the fuel pump, but i was wondering what you thought, and what wires to check to see if it is getting power.
Nov 1, 2007 at 5:32 AM
DAVE H
  • 13,383 POSTS
start by checking the Inertia Switch Next to left fascia fuse box
Nov 29, 2009 at 12:27 PM
Suggested Repair
Before replacing the fuel pump, check the inertia switch next to the left fascia fuse box.
Conversation Summary
The owner of a 1999 Jaguar XK8 reports loss of power, rough running, and fuel pressure that drops to none after the car sits, and suspects the fuel pump. The expert advises first checking the inertia switch next to the left fascia fuse box.
