2005 Other Jaguar Models 2005 s-type, sudden engine failure
2005 JAGUAR
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
RALEIGH1232
  • 7 POSTS
Hello, My s-type has been running great but every once in awhile all of the warning lights will come on and the car will stagger then no longer accelerate. The engine continues to run. So I turn off the car and turn it back on and it is fine...for a while. What could it be and what can I do? --Raleigh
Nov 13, 2008 at 2:18 PM
JAMES W.
  • 2,394 POSTS
Do you get any check engine or VCM codes?
Nov 13, 2008 at 3:11 PM
RALEIGH1232
  • 7 POSTS
I have not taken the car to a mechanic yet. But I did notice that it is happening much more often lately. The car stopped responding to the gas pedal and and all of the warning lights came on seven times today. Also, when I put the car in park to turn it off, the rpm's jump to 2000. There is also a yellow check engine light on constantly.
Nov 14, 2008 at 10:22 AM
JAMES W.
  • 2,394 POSTS
You need to scan the ECM, or have it scanned to find out what tripped your check engine light. This should pretty much pinpoint your problem. Keep me posted.
Nov 14, 2008 at 10:53 AM
MASTERTECHTIM
  • 4,750 POSTS
the reason he asks about the check engine light is because that will give us the best starting point for our diagnosis. autozone scans the computers for free. it sounds like you may have a problem with the accelerator position sensor, we have seen a lot lately, not neccessarily in jags but overall.
Nov 14, 2008 at 10:55 AM
RALEIGH1232
  • 7 POSTS
O.k. I went to Autozone and got the codes. They were P1111 and P2135. They also printed out a little sheet of paper for me which states that "the ECM detected TP 1 and TP 2 do not agree." Also, it lists the probable causes as 1) "failed throttle position sensor" 2) open or short circuit condition. What's my next step?
Nov 15, 2008 at 8:10 AM
JAMES W.
  • 2,394 POSTS
I recomend you change the TPS, throttle position sensor.
Nov 15, 2008 at 8:55 AM
RALEIGH1232
  • 7 POSTS
I can't find a TPS for a 2005 S-Type anywhere but a 2000-2004 is easy to come by. Any idea why?
Nov 15, 2008 at 9:25 AM
MASTERTECHTIM
  • 4,750 POSTS
i believe it comes free with a throttle body assembly. here is a web site of a place i just had a saab throttle body rebuilt from that had the same problem. bba-reman just google it. they will actually take your throttle body and rebuild it if they dont have a exchange.
Nov 15, 2008 at 11:26 AM
RALEIGH1232
  • 7 POSTS
Is it possible that I just need to have the throttle body cleaned? Also, how much would a rebuilt throttle assembly cost me compared to a new one?
Nov 16, 2008 at 10:45 PM
JAMES W.
  • 2,394 POSTS
Raleigh, The availability of a TPS sensor, by itself, is not looking good. I have a few people looking and am waiting for more info. The price of a complete "new" throttle body is about $1300 bucks. To answer your question on cleaning the one you have. You could try it, but there isn't much there to clean. What I need from you to expand my search is the following.
Vin #
2 wheel or all wheel drive
Motor size; 2.8 or 3.0
Transmission type
Let me know on the above and I can check further, Jim.
Nov 17, 2008 at 1:16 AM
RALEIGH1232
  • 7 POSTS
James, I appreciate you going through all the trouble! It is a 3.0 liter V6, 2005 S-Type rear wheel drive, automatic. The vin # is sajwa01t05fn27056
Nov 17, 2008 at 2:19 AM
RALEIGH1232
  • 7 POSTS
I found a throttle body on ebay motors that the seller claims will work. If you have time I would really appreciate you opinion. It is ebay item number 190210026581. AAAmanagement is the seller.
Nov 17, 2008 at 10:58 AM
JAMES W.
  • 2,394 POSTS
I'll check it out and get back to you.
Nov 17, 2008 at 11:36 AM
