2003 Other Jaguar Models GEARBOX FAULT CODE
2003 JAGUAR
44,374 MILES • V8 • 2WD • AUTOMATIC
REBA L SMITH
MY CAR HAS A KICK TO IT WHEN YOU APPLY BRAKES LIKE IT WANTS TO KEEP GOING. WHEN IT TRIES TO CHANGE GEARS IT WILL SNATCH INTO GEAR LIKE IT SUDDENLY POPS INTO GEAR. SOMETIMES IT WILL NOT CHANGE GEARS, YOU HAVE TO CUT THE ENGINE OFF SO THE COMPUTER WILL RESET ITSELF. HOW EXPENSIVE IS IT TO REPAIR THIS PROBLEM? DO YOU HAVE TO REPLACE THE TRANSMISION OR WHAT WILL CORRECT THE GEAR CHANGING PROBLEM?
Sep 25, 2008 at 6:11 AM
DAVE H
  • 13,383 POSTS
you need to have a good transmission shop look at the vehicle
Feb 7, 2010 at 8:03 PM
