2002 Other Jaguar Models piston in caliper
2002 JAGUAR
95,000 MILES • 6 CYL • AWD • AUTOMATIC
ZACHW
could you help me plse i can not figure out the way to reset the caliper so i can put new brakes on the car. we have bosch brake calipers on the jag. can you help?
May 30, 2008 at 6:16 PM
MERLIN2021
  • 17,250 POSTS
Open the cap on the master cylinder. Leave the cap in place but loose, if the caliper has a parking brake cable attached, you need the caliper tool to scdew it back into the bore, line up the notches at 6-12 clock position so the tab on the pads fits in. If no cable, push back by putting one of the pads against the piston and use a C-clamp....
May 30, 2008 at 8:55 PM
