2002 Other Jaguar Models Check engine light
2002 JAGUAR
35,000 MILES • 6 CYL • AWD • AUTOMATIC
OLDTECH2
  • 64 POSTS
I understand that there is a procedure to check the codes in the engine that triggers from the turn signal stalk. However, I've never seen it, and I don't have my manual on the car yet.
Can you enlighten me on this one?
Jan 3, 2008 at 1:06 PM
FSTRANGER302
  • 117 POSTS
[quote:f82626e1b7="oldtech2"]Engine problem
2002 Other Jaguar Models 6 cyl All Wheel Drive Automatic 35000 miles
Can you enlighten me on this one?[/quote:f82626e1b7] hello, the check from the turn signal stalk will not actually tell you what codes are in the computer. it is a way for the engineers to look at the gas tank senders and other funtions.. you should go to your auto part store they usally check codes for free. hope this helps let me know thanks... rep points aprricated if the information helps you
Jan 19, 2008 at 5:33 AM
