2001 Other Jaguar Models engine misfire
2001 JAGUAR
TREVOR WELSH
Engine Performance problem
2001 Other Jaguar Models 6 cyl Two Wheel Drive Automatic 83'000 miles
Qualified mechanic requiring info on the procedure for replacing spark plugs on an S-Type Jaguar.
Jun 27, 2008 at 11:52 PM
DAVE H
  • 13,384 POSTS
Ignition Coil-On-Plug
Removal
Left and Right-Hand Bank
Disconnect the battery ground cable.
Remove the engine cover.
Left-Hand Bank
Remove the evaporative emission canister purge valve. For additional information, refer toEVAPORATIVE EMISSION CANISTER PURGE VALVE .
Remove the oil level indicator.
Detach the power assisted steering fluid reservoir.
Unclip the engine breather hose.
Right-Hand Bank
Remove the air intake tube. For additional information, refer to AIR CLEANER OUTLET PIPE .
NOTE:Left-hand bank shown, right-hand similar.
Remove the ignition coil cover.
Disconnect the ignition coil electrical connector.
Remove the ignition coil.
Remove the spark plug
Installation
To install, reverse the Removal procedure.
Oct 30, 2009 at 11:24 PM
