2000 Other Jaguar Models engine cuts out
2000 JAGUAR
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
DURTYSANCHEZZZ
I have a 2000 jaguar S type with a v6. The car starts with no problem idles fine and runs great. I don't have any problems accelerating from a stop. The only time I have any trouble is at a cruising speed. If I hit a small hill and have to give it a little more gas to maintain speed it chugs and acts like it's cutting out. I can give it alot of throttle and it will stop chugging and accel fast with no problem. At first I thought it was my transmission or the lockup converter not working properly. The more it happens the more I think it's an engine problem. Any advice you could give would be great.thanks
Jun 10, 2008 at 2:57 PM
GEORGEJAGUAR
  • 10 POSTS
hello jaguar dealership technician here i suspect you have a coil breaking down under loads , hills a juguar dealership can use there 510 scanner a nd look at misfire moniters and i bet he will find misfire faults iin the moniter and which sylinder it is
Jul 11, 2008 at 3:48 PM
