1997 Other Jaguar Models emergency brake help.
1997 JAGUAR
69,000 MILES • V8 • 2WD • AUTOMATIC
DRMUFF
Hi, the e-brake handle in my 1997 jag is stuck on. the release isn't working and the handle has no tension, so i believe the problem is in the front part of the system. is there a way to manually release is without using the handle? its got disc brakes all the way around if that helps. thank you,
Drmuff
Aug 17, 2008 at 5:10 AM
DAVE H
  • 13,384 POSTS
we need exact model details to assist !
Feb 7, 2010 at 7:45 PM
