1962 Other Jaguar Models misfire, afterfire
1962 JAGUAR
100,000 MILES • 6 CYL • 2WD • MANUAL
EDRIVER
Is it possible that not enough valve clearance can cause a misfire and afterfire (out exhaust) when engine is run steady at higher rpms? It idles fine and revs easily. A valve job was just done and the valves must have seated some. The cold spec for the 4.2 liter is .004 intake and .006 exhaust and when I just checked them they were about .002 -.0025 on the intake and .003 -.005 on the exhaust. I'm restoring the car and it wasn't running when I got it. Almost everything on the motor has been rebuilt or is new. I've checked and rechecked everything I can think of but it won't run right. What do you think?
Bill
May 17, 2008 at 7:24 AM
DAVE H
  • 13,384 POSTS
valve clearence has to be exact
Jan 17, 2010 at 12:23 AM
