1962 Other Jaguar Models Front side-to-side ride height unev
1962 JAGUAR
10,500 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN B ANDERSON
Jag Mk 2 3.8 workshop manual recommends using spring spacers positioned on top of a spring to offset the effect of uneven length front springs. I have tried to locate spacers but suppliers say "no longer availalble". Do you know a source for correct type spacers, new or used?
I have seen this problem addressed with spacer washers installed on the retaining bolts of the the lower spring support, but feel that this puts unacceptable stress on the bolts due to the reduced length of the bolt thread used. The rear suspension has been rebuilt with all new parts and I am sure the ride height problem is in the front suspension.
Nov 30, 2009 at 1:47 AM
HMAC300
  • 48,601 POSTS
a car this old suffering from uneven height should have new springs put in first before you ever add spacers. yor post doesn't say you did. I have anMGB and alot of times the spring quality is poor and that causes it as well. If you know a machine hop try them they could always measure one up and make one.
Jan 17, 2010 at 11:11 AM
