jaguar cranks but wont start., was functionig well the day before
65 MILES
RUBEN DIAZ-RODRIGUEZ
there is no ground in terminal 85, orange cable in the fuel pump relay. when i ground it and put tthe ignition switch on, the fuel pump start. could be the ECU but needs an expert opinion, thank you RUBEN
Apr 11, 2013 at 10:40 AM
HMAC300
  • 48,601 POSTS
the brown wire is from battery so that should give power but check your main relay because I think that activates the fp relay and the blue red wire goes to fp where it grounds through that. this is form an xj6 as I don't know what model you have. wite brown wire is from main relay and pink/brown wire goes to ecu which probably turns it on
Apr 11, 2013 at 11:30 AM
