Jaguar codes P1316,P0353, P0354, P0355, P0356, P0358
94,300 MILES • 4.0L • V8 • RWD • AUTOMATIC
BLACKHONOR9
  • 14 POSTS
I'm getting these codes on my 2000 Jaguar Vanden Plas. I know that code 0353, 0354, 0355, 0356 are coil codes. So I moved coil 3 to 1 and 4 to 2 and coil 5 to 7 and 6 to 8. Still getting same codes with an additional P0358. i hoped the misfires would move but didn't. What should be the next step I take?
Dec 8, 2014 at 10:34 PM
WRENCHTECH
  • 20,760 POSTS
Those are coil CIRCUIT codes not coil codes. That means it could be anything in the circuit to include wiring, power supplies and the computer. The wiring would be your most likely suspect. I'd specifically look at connectors for that harness.
Dec 8, 2014 at 11:25 PM
BLACKHONOR9
  • 14 POSTS
I forgot to mention that I am receiving Coe P0305, P0304. How can I check the wiring or connectors?
Dec 9, 2014 at 2:56 AM
WRENCHTECH
  • 20,760 POSTS
If you don't have electrical training and knowledge and it appears you don't, then this is likely going to be a job for an electrical shop.
Dec 9, 2014 at 7:16 AM
