Jacking up my car
132,000 MILES • 3.6L • 6 CYL
MARLAINA PETERS
  • 7 POSTS
I want to use ramps instead of jack stands. I am draining coolant.
Oct 2, 2017 at 2:00 AM
JDL
  • 16,098 POSTS
Okay, is there a question? I have a set of those hard plastic ramps. If you use them on pavement they slide, have to put them up against porch step to keep them from moving. Also, the incline is smooth, so my fwd vehicle will spin the tires trying to get up the ramp. I have seen metal ramps where the incline had punched out holes, the edges of the holes were raised, so at least with a four wheel drive vehicle, the tires have something to grab. Although I have never tried them. I think I like the metal ones better.
Hopefully your radiator has drain valve at the bottom, if not, pulling the lower radiator hose should drain it.
Oct 2, 2017 at 2:44 AM
