Rough idle, engine stutter, intermittent check engine light
180,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
NYGLEE
I have a rough idle and a stutter between 40 and 60 miles an hour and an intermittent check engine light that will be on for a day and then off for two days.
I have changed the ignition control module, the crank sensor, the cam sensor, all the wires and the plugs are about a year old.
Aug 5, 2018 at 11:09 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Have you been able to have the code retrieved and can you supply us with the code number? That helps us with diagnosis . If you do not have a scanner/code reader you can take your car to your local auto parts store (Pep Boys, AutoZone,O'Reillys) and they will check for free. Once you get back to us with the code numbers we will be happy to help. I have attached a link showing what is involved. Hope this helps and thanks for using 2CarPros.
Danny-
Aug 5, 2018 at 12:12 PM
