Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Fuel System
Fuel Pump
Relay
Fuel pump not getting power?
1999 TOYOTA CAMRY
201,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CHEYNE
MEMBER
1 POST
Looking for the relay. Looking for the relay.
Nov 30, 2019 at 5:21 AM
DANNY L
Experienced Mechanic
Hello, I'm Danny.
The fuel pump relay is called a "circuit cut relay" located under hood in the relay box.Here is a tutorial showing how to test a relay:
I've attached a picture below of its location.Hope this helps and thanks for using 2CarPros.
Image (Click to enlarge)
Nov 30, 2019 at 10:31 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
