Itasca/Winnebago Lesharo/Phasar
45,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
MARK BEYER
Unable to find the rear axle bearing seal part number or source. The Renault Trafic was used as the chassis for the winnebago Lesharo and the Itasca Phasar. Really need this axle seal. 1985-1986, Vin number available
May 2, 2016 at 3:43 AM
HMAC300
  • 48,601 POSTS
try ebay under commercial vehicles, but parts will probably come from Europe. Or go to an auto parts and see if you can match one up, preferably one that stocks foreign car parts.
May 2, 2016 at 5:06 AM
MARK BEYER
yeah, been trying, no luck so far, that is why I am here.
May 2, 2016 at 6:01 AM
HMAC300
  • 48,601 POSTS
I typed it in uder google and it went right to ebay on the searches it found. nothing to match at auto parts I take it. you might try a truck shop that handles medium duty trucks. I used to work on those and most had a dana 60 or 70 unit in them. which are pretty big.
May 2, 2016 at 6:30 AM
MARK BEYER
its a front wheel drive, straight axle in the back.
everything seems to be overseas.
May 2, 2016 at 6:37 AM
  • 31,937 POSTS
You may just have to take a sample seal to a bearing supply to match it up, if they can measure it they should be able to match it, mi did this for a bearing and seal from a 1920's engine with no problems.
May 4, 2016 at 7:38 AM
