It will not start on first start of the day
150,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
LACEYBUGG2125
I have to spray starter fluid to start it in the morning, it takes a few tries then once started it keeps starting the rest of the day until the next morning.
Apr 30, 2020 at 4:44 AM
Good afternoon,
This sounds like the fuel pump is losing its prime and draining back to the tank.
Then it takes a couple of key cycles for it to get to full pressure for it to start.
I would check the fuel pressure before you start it in the morning. then also check it running.
Fuel Pressure (Key "on", Engine "off") .................... 358-405 kPa (52-59 psi)
Apr 30, 2020 at 5:24 AM
