It will not start
140,580 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ELENO LERMAJR
We jump it it turns over makes all the right sounds but won't start.
Dec 6, 2019 at 2:39 AM
  • 110,248 POSTS
The first thing that needs checked is to see if there is fuel to the engine and ignition spark to the plugs. Take a look through these links:
If you want, see if it will start for a couple seconds if you use starting fluid. If it does, then we know it is a fuel related issue. If it still fails to start, then it is ignition related.
Let me know what you find and if this issue started all at once.
Dec 6, 2019 at 12:49 PM
