Will not start after shutting off while driving
240,000 MILES • 2.5L • 5 CYL • 2WD • MANUAL
MKOMAPE
Hi, I haven’t driven it for over two months. then when I drove it started jerking, then the engine stopped. now it won’t start.
Jan 6, 2019 at 1:32 AM
  • 110,248 POSTS
Many things can cause it not to start. Take a look through this link and let me know if it helps.
Take care and let me know if this helps.
Jan 6, 2019 at 12:39 PM
MKOMAPE
Thanks for the response.
Jan 7, 2019 at 3:31 AM
  • 110,248 POSTS
No problem. Let me know what you find or if you need additional help or information.
Jan 7, 2019 at 8:55 AM
  • 55,694 POSTS
Did you find out the problem? When you turn the key to the on position without cranking the engine can you hear the pump run in the tank?
Jan 8, 2019 at 2:30 AM
