It will not pull
180,000 MILES • V8 • AWD • AUTOMATIC
DFOSTER69
I was driving down the highway and with no warning it stops pulling. It will start and go in gear, but when you press on gas it just revs up and makes a rattling and whining noise.
Feb 27, 2017 at 11:29 AM
KHLOW2008
  • 41,812 POSTS
Description indicates the transmission has most probably failed. Check the transmission fluid level and condition of fluid if level is correct. If the fluid smells burns and fluid color is very dark, it could mean the transmission is slipping internally.
Feb 28, 2017 at 12:27 AM
