Battery goes dead
20,000 MILES • 0.6L • 4 CYL • 2WD • MANUAL
LAURA HUMMEL-GREENO
I have replaced the battery, alternator,ign control module and it still won't hold a charge. What could I look at next?
Apr 7, 2019 at 2:02 AM
SEVAG P
  • 405 POSTS
hello thanks for using 2CarPros.
It seems you have a blown fuse for alternator fuse 20 15A at engine compartment fuse/relay box or the wiring problem leading to the alternator.
Check our guide:
Perform the tests step by step at the files attached below and the wiring diagram specific to your vehicle.
Apr 7, 2019 at 2:24 AM
LAURA HUMMEL-GREENO
Thank you so much. It works.
Apr 7, 2019 at 3:42 AM
SEVAG P
  • 405 POSTS
You are welcome. let us know if you need more help.
Apr 7, 2019 at 4:25 AM
LAURA HUMMEL-GREENO
I will thank you so much. I was three weeks without my truck.
Apr 7, 2019 at 5:15 AM
SEVAG P
  • 405 POSTS
Please feed back what was the problem???
Apr 7, 2019 at 5:23 AM
LAURA HUMMEL-GREENO
It was the fuse.
Apr 7, 2019 at 6:23 AM
  • 55,743 POSTS
SEVAG PAESEGHIAN is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Apr 9, 2019 at 7:07 AM
