Took a jumper wire and tried to jump it across from positive side to negative and it smoked and now it will not start
207,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
KENNETH1516
So I just bought the van. seemed like a good buy until i got home and realized the fans wasn't working and saw that it was overheating after I got home after a two hour drive. so I found the fan relay switch and I took a jumper wire and tried to jump it across from positive side to negative and it smoked and now it wont start. can and would you help me please? the only thing it does is click and acts like the battery is dead or has a loose connection. but the battery is good and tight and didn't bother with the battery.
Sep 26, 2019 at 8:06 AM
  • 55,711 POSTS
You could have knocked the battery out. here is a guide to help test it. Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Sep 27, 2019 at 11:51 AM
