Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hummer
H3
Climate Control
Air Conditioner
Switch
It will not switch from A/C to heat
2007 HUMMER H3
188,000 MILES • 5 CYL • 4WD • AUTOMATIC
MIKEVOL4LIFE
MEMBER
1 POST
I do not know which actuator controls this, there are 3 of them. Are the same part number to order?
Apr 1, 2020 at 5:20 AM
Experienced Mechanic
Good afternoon,
According to Alldata, you have separate controls for each side. Are both sides not working?
To be sure, is the A/C system working? Did you see if the compressor is engaging and can you check the pressures?
Images (Click to enlarge)
Apr 1, 2020 at 5:40 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
