It will crank over but will not start
189,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CLAYTONBELL67
It will crank over and act like it wants to start but it will not start. The engine is getting gas. I do not know it I should replace the CMP or CKP sensor.
Oct 27, 2018 at 3:44 AM
WILLIAM CRABTREE
  • 95 POSTS
So there are a few things that could be causing your issue. First, I would suggest pulling the check engine codes (if there are any). Below is a link with more information on how to do that.
The next link is a list of other possible issues that could be preventing the car from starting.
Next, is a crankshaft sensor link.
It does sound like it could be a crankshaft position sensor, but I would follow the testing suggestions in the links I gave you before you spend the money on the part!
Keep me posted on what you find, and let me know if I can be of any more help.
William
Oct 27, 2018 at 6:57 AM
