Engine it was idling, then stopped and now it will not start
111,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
LAZYRUS CLUBBERLANG
replaced ECM, CKS, ignition and electrical switches. It was running, after replaced ECM. The fuses are okay. ASD and fuel pump relays replaced.
used testing light, power to everything relays, coil.
Apr 12, 2022 at 6:53 AM
  • 55,770 POSTS
If you spray starting fluid into the intake, does it start and run for a few seconds? Also, can you hear the fuel pump run in the tank when you turn the key on without cranking the engine over?
This guide can help:
Let us know what happens and please upload pictures or videos of the problem.
Apr 13, 2022 at 9:59 AM
