It wants to quit running when going to accelerat
170,000 MILES • 4.9L • V8 • RWD • AUTOMATIC
JASONUNDER
It idles ok but when u go to give it gas or excelerate or pump the gas pedal it's like the car s**** off until u let off the gas pedal have to feather the gas pedal for it to accelerate and it idles high then low over n over
Mar 1, 2014 at 4:13 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
id check for a vacuum leak first. crank the engine and spray all around on the top and listen for a rise in rpms. leave the air filter housing on so you don't get a false reading. if it rises you should check all the little black rubber vacuum lines first.
Mar 1, 2014 at 7:11 PM
