It used to start for a few seconds then shut off but now it will not start
190,000 MILES • 2.8L • 4 CYL • FWD • AUTOMATIC
TONE KENDRICK
Only starts if i spray the throttle body. It is getting fuel, changed throttle body and coil pack. Still will not start. Help
Sep 19, 2017 at 5:50 PM
STEVE W.
  • 15,402 POSTS
If it will start on spray you are not getting fuel through the injectors. What is the fuel pressure? You should have 40-47 psi at the throttle body (with 10 in. of vacuum applied to the fuel pressure regulator) Any less and it will not run.
Sep 19, 2017 at 8:41 PM
